lastcowboy32
We have a three year old tractor.
I am specifically withholding the brand name, because I want to know if this is common among brands.
When I went to change the universal transmission/hydraulic fluid, I went to a dealer, they sold me a 20 weight universal transmission/hydraulic fluid.
I actually had the manual with me and showed them the page where it said that the tractor needed 75weight fluid.
I was told that the manual was wrong.
I questioned that... then they asked... Did you drain the tractor? I did. And they asked, What did it flow like?
I have to say, the oil flowed out of the tractor like motor oil, not 75W gear oil. Then I got thinking about how that same oil runs all of the hydraulics and has to get pumped around the tractor...
How the heck would you pump 75W gear oil out to a loader cylinder?
He also asked, What did it smell like? Like gear oil? My answer there is no.
What he said is that the manual confused the gear oil for the four wheel drive front end... which SHOULD be 75W gear oil... with the universal transmission/hydraulic fluid in the back end.
Does anybody have a brand of tractor that specifies 75W oil for the universal transmission/hydraulic oil in the back end???
My tractor, specifically has gears, so it's not fully hydrostatic, but it has wet brakes, a power reverser, a hydraulic clutch and a hydraulic PTO clutch. It also has two full remotes and a loader, which need to run from this same sump.
