Good afternoon. I few weeks back I posted looking for some help on my NH Super 66 baler. I am still stumped.
The problem is that the knotter shaft is not making a complete revolution. I have attached a video of the knotter arm when the baler is under power from its Wisconsin TFD. Just before the video starts, I have pulled the yoke rod (seen coming up from the lower right of the video) rearward (to the right in the video) until it seems to lock into a detent--note it is just "past center." Then, I trip the knotter clutch, and the knotter arm makes about a 350 degree revolution--not a full 360. This is a problem because now the yoke rod is not "past center," and hence creates the risk that the weight of the yoke itself will tend to work down against the needle brake and put the needles in the chamber, triggering the safety stop. I have had some spectacular failures because of this.
If you watch the video, notice how the arm pulses--"clack, clack, clack"--like it wants to go the last inch or so, but will not.
I know it is hay season for nearly everyone else, so I appreciate the time to respond. Any insight is appreciated. Meanwhile, it's fix-baler season for me, all while it hope it doesn't rain.
My apologies if the video displays rotated 90 degrees. I tried to edit but am not sure it worked.
Thanks in advance,
Dave
[video play=false:654c4848f0]https://www.yesterdaystractors.com/cvvideos/cvvideo49676.mov[/video:654c4848f0]
Thanks in advance,
Dave
