Caroline Chamblin
I don't know.
asiest way to determine that is to watch the rotor as engine is being cranked. Turning?(quoted from post at 16:41:45 07/12/23) I don't know.
s HoBO SAID, BE SURE CRANK PULLEY IS TURNING. mINE WAS AS SIMPLE AS a FEW WELDS ON FLYWHEEL TO RING GEAR THRU STARTER MOUNTING HOLE. oTHERWISE PROBABLY CAM GEAR, WHICH YOU CAN SEE THRU GOVERNOR MOUNT HOLE.(quoted from post at 07:09:57 07/13/23)
Make sure the crankshaft is turning, the crank turns the cam. It would be rare for something to go wrong at the flywheel but it does happen.
If the crank spins and the cam does not its a major job to repair. I would pull the engine and take the pan off.
(quoted from post at 18:45:22 07/12/23) Just fyi internal break inside W camshaft gear
possibly
ruce, if it is a press-on gear, as in my picture from 1941, it is still available (on YT) and does cam have to be removed to remove gear and press on another?(quoted from post at 16:35:12 07/13/23) Well, that will sure result in no spark!
Hopefully, it's just the timing gear. Pul the governor off and look in there to see.
Post back w/ results, pls.
And see tip # 1
75 Tips
