Question then background. Where would I hook jumper wires to test a 12v tractor generator with a working gauge from a parts tractor? Worst part is, it's a British built David Brown disguised as an Oliver. The terminals on the generator are D and F. Dynamo and Field I assume instead of Generator and Field?
I was going to take the hood off and just jump to the back of the existing gauge, but when I gotit off, the gas tank is in the way. The gauge that's on the tractor now doesn't show charge or discharge, just battery condition with brown and green on the stripe across it with numbers from 8 to 14 or some such thing. Even after a full charge with the battery charger, it's sitting near the bottom at about 8.
The tractor sat all winter with a battery that was new a year ago. It started right up this spring. We took it to town for a show Memorial Weekend and it was fine. I went to start it Sunday and the battery was totally dead. I jumped it and when I took the cables off, it kept running, so I assume it was running off the generator. However, after charging the battery Sunday, it started right up Monday morning. I put the charger back on it just to be sure it was topped off. I loaded it on the trailer, took it to a parade and drove it for about two hours. When I got back to the trailer, I had left the ramps down, so I just backed it on and shut it off. When we got home, the battery was too weak to start it and we had to start it by rolling it down the ramps, leading me to believe the generator isn't working after all.
This morning, it rolled about like it did Monday on the trailer. I jumped it again, it ran fine, but when I shut it off in the shop, it was dead as a door nail. The regulator is up under the dash covered up by the gas tank too. I just don't want to pull that tank out without testing that generator first. I need to troubleshoot everything to find out of there's a short drawing the battery down, or if the regulator is sticking or just what's going on. I have a multi meter, but I have no idea on earth how to use it. Everything on there might as well be written in Arabic.
