Nuffield engine options
Lloyd54930
I have a Nuffield 3/45 with a bad engine block. Does anyone know of guys that have put other makes of engines in one of these tractors? The 3 cylinder diesel is hard to find.
- well, I am not going to say it is impossible, but I will say it is sure not going to be easy, 20 years of working on them, and I have had lots of guys with "plans" to convert them, but never seen one happen yet
- possibly one of the smaller Japanese or Korean diesels might be a starting point, but with the web in the frame under the rear crank seal area, and the need for a full sized flywheel to attach that big clutch too, it just does not seem worth it
- a donor 245 with engine and front frame carrying a nice perkins would work, but unless something drastic happenned they never wear out transmissions, the trans can handle a lot more power than the little 3 cylinder can put out
- unless your block has a big hole knocked in the side or cracked between the cylinders at the bottom, just fix it and carry on would be the way to go
- one other option now I think of it, engine out of a 3/42 will fit in the spot, but your goin older instead of newer, and it is a different engine so most parts off it will not swap
good luck to ya
