dirtroader
Hey guys, I purchased a 1975 Oliver 1365 FWA recently. Really excited about it. Just digging into it for repairs now, restoration to follow sometime in the future. Some questions popped up that I hope you guys can help me out with. The thermostart system. Was that standard? Someone in the past took the multi position starter lever off and replaced it with a button (I assume it was replaced). I also do not see the tank on top of the engine that is supposed to hold the fuel for the thermostart.
Secondly, the power steering works, but lot of play in the steering wheel. I accessed the power steering system under the battery box and attempted to adjust and understand the system. It seems like the only correction is to replace bushings. Are the main pin bushings under the grease fitting the most likely cause? Everything connecting directly to the steering control valve seems fairly tight and in good condition. I assume the play I have is abnormal, it's been many years since I operating a different 1365 growing up on the farm.
And thirdly, where is the best parts source for these old girls? I need parts for the things mentioned above, a left fender (someone cut it so it would be easier to get on and off the tractor) a seat, and misc seals. For now haha.
Thanks a bunch, and look forward to the project and talking shop with you all.
Jesse
Jesse
