Gleanerguy
I am putting an alternator on my neighbor's 550 Oliver tractor (1964 model).
Presently it has a generator with an external regulator. The tractor has no ammeter. It has a positive grounding system.
I would be changing over to a standard negative grounding system with a one wire alternator with a built in regulator.
Am I correct- that I would need to switch the wires at the coil (the wire from the starter and the wire going to the distributor)? Thanks.
