Danny in CO
INFO: 99 Dodge Grand Caravan, 3.3L engine, Front wheel drive.
PROBLEM: Speedometer quit working and transmission won't shift above 2nd gear. Mechanic said is was probably a speed sensor on the transmission.
Question: There are 2 speed sensors on this model: an input sensor and an output sensor. I found the output sensor and replaced. It was on the end of the transmission close to the driver's front wheel. I have looked all over the transmission and cannot find the other speed sensor. Anyone have any idea where I should look?
I'm a Doofus: The power steering pump was making a grinding noise. I figure it is low on fluid. I take the cap of the reservior and put about a quarter of a cup of fluid and its full! Huh I say! Then the STUPID wears off and I realize I just filled the brake fluid reservior! DOOFUS! DOOFOS! I find the REAL power steering reservior and fill it with about a half a quart of power steering fluid. Grinding stops!
Question #2: Do I need to drain the fluid out of the bakes and refill with REAL brake fluid? My thought is that both brake fluid and power steering fluid are hydraulic fluids and I don't think a quarter of a cup of power steering fluid in the brakes will hurt anything. Am I wrong?
Thanks,
Danny
PS: I promise I won't do anything else stupid tonight. I'm going to bed!
Thanks,
Danny
