Penetrating oils ........... Average torque load to loosen*
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission
fluid and acetone. Note this "home brew" released bolts better than any
This info is from a magazine who tested in a controlled environment. It also stated that ATF and 50/50 mix of lacquer thinner is as good as acetone mix.
They also stated that Liquid Wrench is almost as good as Kroil for 20% of cost.
I usually use PB Blaster and it didn't fare to well it appears.
