plow problems
glf73
WHEN PLOWING WITH A 350 INTERNATIONAL UTILITY IT SAYS IN THE BOOK TO FREE THE LATERAL SWING WHICH I'VE DONE FREE THE SOCKETS AND THE CYLINDER BELL CRANK AND I'VE DONE, BUT I CAN'T GET THE PLOW TO ROLL OVER THE SOD, DO I NEED TO LOWER THE RIGHT SIDE OR WHAT AM I DOING WRONG, HELP
How deep is your plow going in to the soil?
How tall is the sod you're trying to turn under?
If the plow shears are not correctly sharpened they won't draw deep enough into the ground.
If it's a three point plow you may have to adjust your third link.
Can you post some pictures of what it's doing?
John
Furrow width too narrow in relation to depth, max depth is ussually around 60% of the furrow width.
Shares too wide, when ploughing grassland, especally old stuff you need a lot narrower share than you can use in subble or other looser ground
Is the plough pitched too far forward? the mouldboards will not work prperly if it is, adjust top link to suit
The plough, when in work should appear level from all directions
Check the disc coulter settings, you may have to run deeper than normal so the mouldboard starts to turn the furrow slice quickly, or it will lift the furrow straight up before turning it.
Sometimes a bit of extra speed helps, if you are using a short board plough, which most American and Canaidian ploughs were, use tailpieces on the mouldboards. If your plough has adjustable moulboard stays these can be used to advantage.
Most common problem with sod not turning over is attempting to plow too deep. Next most common mistake is plowing too slow.
Folks get mad at me 'cause I tell it like it is and I'm kinda blunt about it. No disrespct meant in any way; just the way I talk.
However, a 30 horse tractor is never, ever gonna pull a two bottom plow in sod. Just isn't gonna happen.
It won't pull deep enough and it won't pull it fast enough.
Allan
Huh? I must respectfully disagree with that opinion Allen... Think about your statement... 30 hp...
Sod isn't anything special... get under it, cut the roots.. flip it over... big whoop...
For the OP... need more info, photos help...
I too disaggree ive plowed many a acre of new ground with a 23 hp 2n.first if its a three point plow.set your tractor on the level and lower plow,set the plow to where both points touch the ground evenly.now adjust toplink to where rear of landslide is up 3/4-1" higher than points.plow your first furrow(s) then run left rear wheel in furrow(if plow throws to right).again set plow as above.to see if soil is too wet or dry to plow dig down about a ft with shovel,pick up a handful of soil and squeeze it,if it sticks together and doesnt break apart easily its too wet,if it wont stick together at all its too dry,if it sticks together but breaks apart easily start plowing and dont quit till your done!dont know what size plow your pulling but all plows are made to plow 1/2 the width,in other words,if you have a 14" plow(width) it should plow 7" deep.set your coulters! again i dont know what plow your using but a general rule of thumb would be bttm of coulter 1 1/2" above point of plow,and offset to right of shin about 1".worn shares will cause high draft and slow down speed,making furrows not turn well.as will rusty moldboards not scouring well.if your plow moldboards are rusty clean them as best you can with wire brush,and then just plow with it until it shines up.a real clean one will be like a mirror,and nothing will stick to it.when you get it (or them) clean, coat them with a heavy grease when your finished plowing to protect them.hope this helps!
I respectfully disagree too. :>)
Are we talking about the same thing?
Yer honor, exhibit A is plowing under grass; I agree, not much to it. Second picture is sod. Believe me, you'll know that crap when ya hit it.
I've brought three farms into production from sod and ya don't just "Get under it, cut the roots and flip it over". It's a fist-fight at every turn of the wheel.
Allan
Put a few long established fallow, what I'd consider "sod" fields to dirt... Most recently with a 14" 1 bottom equipped Super A and the 560D w/ 412 16"... Done a number of 30+ year old well compacted yards for gardens and a few well established fallowed pastures... 2nd Gear will work her... My experience has been somewhere between the 2 photos you posted... one solid root mass but not nearly that large a slice at a time... Turns as one solid slab... no break-up.
That bottom photo, I'll give it to you... looks like some really fun crap... Actually I'd hate to break it down after plowing... Not sure if my kidneys could take it...
I was going to disagree with Allen, since I've had a two bottom connected to a Farmall 200 working my land for years, until I saw that second photo...
Your sod is not my sod.
Wow.
K
Fer Sure,
I'm thinkin' it's all in the definition of the word "sod". :>)
I pulled this field into production last year. It still had a lot of buffalo wallows in it, which really took some doing to get those holes all worked out.
I know the neighbors think I'm nuts, but it sure raises good crops after it's all said and done.
Allan
