Ted in NE-OH
Has anyone tried to retrofit PCV to an old tractor to solve blowby
actually what tractor ? they actually do have a crankcase ventilation , dont know how positive it is. if your blowby is that bad then u need to overhaul the engine. sucking that much gunk back into the intake is not a good idea anyhow, your not going to solve the blowby this way . it is basically to reburn the fumes from the crankcase not to suck blowby sludge , be pretty hard on the spark plugs with added sludge on already carboned up plugs from oil. plus these old tractors dont run hot enough anyhow for it to work with a bunch of blowby. you need to fix the blowby problem with what it takes , like sleeves pistons rings and valves, so the compression is sealed and not leaking past the rings.Has anyone tried to retrofit PCV to an old tractor to solve blowby
PCV, the way I understand it is to put slight vacuum on the crankcase, to help piston movement. This is why pre-emission, we had the control-era device for ventilating the crankcase to the atmosphere; a pipe routed under the chassis at an angle that produces a small vacuum as the vehicle travels forward. Fresh air is drawn in through a mesh filter in the oil filler cap, circulated around inside the crankcase and exhausted through the road-draft tube carrying blowby with it.actually what tractor ? they actually do have a crankcase ventilation , dont know how positive it is. if your blowby is that bad then u need to overhaul the engine. sucking that much gunk back into the intake is not a good idea anyhow, your not going to solve the blowby this way . it is basically to reburn the fumes from the crankcase not to suck blowby sludge , be pretty hard on the spark plugs with added sludge on already carboned up plugs from oil. plus these old tractors dont run hot enough anyhow for it to work with a bunch of blowby. you need to fix the blowby problem with what it takes , like sleeves pistons rings and valves, so the compression is sealed and not leaking past the rings.
I don't see how retrofitting a PCV set up will solve blow by. It would just make it, so the vapor is not visible, as it is when vented to the atmosphere via the common draft tube.Has anyone tried to retrofit PCV to an old tractor to solve blowby
It does not "solve" blowby but ......Has anyone tried to retrofit PCV to an old tractor to solve blowby
I made one of those out of a glass fuel bowl. The engine did not have room for a baffle under the PCV valve. Worked great.It does not "solve" blowby but ......
Maybe you need/want an oil catch can? Many are out there made and sold ready made.
