farmersamm
While it may just be "lawyer speak"..................most engine drive welders will state in the manual how they can be used when utilized as a generator. My 250GXT manual states that it cannot be used to power sensitive electronic stuff like the computer. Can't speak to other models, but I'm sure there are welders that produce cleaner power. The lights will flicker when the welder powers the house.
One problem with my welder is RPM. The Hz depends on a steady, proper, RPM. If the governor hunts, you can see the variance in voltage. Being a carbureted setup, I'd be pretty sure that a fuel injected motor would maybe do a better job?
I don't run anything by patching at the disconnect. I run only with extension cords. You can't backfeed the utility.......it can hurt someone.
We run our house on Propane. This is a life saver when there's a power outage. You don't lose your heat. I keep a pigtail in the heater cabinet. When the power goes out, I simply disconnect the house wiring that feeds the heater, and put the pigtail in its place.......which hooks to the extension cord. Lot of newer homes around here are built with electric heat..........A huge mistake IMHO.
