john in la
Trudging across my field through knee high grass and weeds headed for my well pump house to investigate low water pressure at the house when I came across a very wet spot.
Yes you guessed it my 1.25 inch pvc water pipe is leaking and water is bubbling out of the ground.
It is leaking right where 2 pipes join together in the pre formed slip joint on the end of one pipe.
I can not see it from all the water in the hole I dug but I can pull the pipe up and down and feal it click as the joint moves.
First time I have ever had a glue joint fail on pvc pipe.
So how do I fix this??????
I am reluctant to use one of those screw together joints with the oring because this will be buried.
I guess I could dig back 10 to 15 feet on either side of the break so I can move the pipes around better to get a new union on both ends but that seems like a lot of work.
I have seen on youtube people grind the stop out the inside of a union so you can slide the union all the way on one pipe and then slide it back to center to join the pipes. This seems like a recipe for a bad glue joint from sliding the union around so much.
I'm all ears for your ideas.
Thanks.
Thanks.
