Looked at a 135 with a MF232 loader this evening that will be going at estate auction Saturday. The son knows the tractor a little bit but not the specifics.
It is gas but I couldn't tell what engine. It had markings all over it but no name or size. How do I tell what engine it is? Also is there an advantage or disadvantage with gas engine?
At the base of the steering column there was a unit with lines going into it. I'm assuming this is the power assist?
It had a bit of oil on the pan and the lights don't work but other than that it is very straight and clean. Tires are good but the wheels are a little rusty around the valve stem so I'm thinking they have calcium. Had a concrete barrel on back because all it was used for was plowing snow for many years. Gear drive.
Any idea of value based on this info?
