Radiator Pressure
Anonymous-0
My radiator does NOT build up ANY pressure. In other words, whenever I remove the cap, even after long trips of 1/2 hour down the road (but doing no "work"), there is never any pressure release. However, there is also NO TIGHTNESS to the cap. I must say that the cap is NEW, but does not fit tightly. Also, I must say that the thermostat is NEW and was put in the correct way. What is going on?
New style radiators are 4psi systems.
If your cap don't fit tight.. it can't build any pressure.
Check the cap for damage and fit, and check the neck for deformation / damage.
Old style 'large tank' 9n had a non pressurized system with funny 'lug on the inside' caps that are not interchangeable with newer style pressurized caps.
Soundguy
Hey SouNdguy,
My N is a 1952. The radiator has been in place for an undetermined time. Got the N from my wife's uncles in Idaho in 2004. Don't know if it ever had any pressure. Am I understanding you correctly that my system may not be a pressurized one? What are the ins and outs of each? I would guess that the pressurized systems can run hotter and therefore make the engine operate more efficiently. Can you tell me more? Thanks, Tom
1952 model had a pressurized radiator from the factory.
Pressurized system raises the boil point of water.. just like a pressure cooker does..
soundguy
My 9N is the same way and it has never over-heated, even after plowing or discing for 2 or more hours straight. Until I put in a thermostat it never even got beyond luke warm. Now it gets hot but does not boil.
"Need a radiator for a '42 Ford 9N. Aftermarket aluminum ones come with 19 PSI caps, but the 9N needs 0–4 PSI. I hear getting a low-pressure cap to fit the throat on those AL radiators is tough. Is it better to stick with an original-style brass/copper replacement?"
Pressure is caused by a liquid getting hot and expanding in a closed container, if the container isn't closed there is no pressure. That said N's used a low pressure radiator cap so it's not going to build much pressure. The biggest problem is overfilling the radiator and the expanding coolant has nowhere to go but out the overflow tube. People think there is something wrong when actually the only thing wrong is they overfilled the radiator.
