Hello to all,
It's been quite awhile since I've posted, but I hope everyone is doing great.
The 51 MT has been down at least since 2012 in a shed covered by a tarp. I am going to get her back up and running, and wanted to know what you guys suggest I do before cranking her up again, or try to get her running.
1.I pulled the carb and need a carb rebuild kit. I also need a few of those felt retainers for the brass parts on bottom of lower carb bowl? Any suggestions?
2.I was going to change the oil, oil filter, oil breather/bath, TOM Fluids, drain old gas and replace w new [clean sediment bowl too] and see if the radiator fluid needs changing. If so, I'll use distilled water and premix antifreeze at about a 70-30 water/antifreeze ratio - does this sound correct?
3.Perform a lubrication of all the key areas per the MT maintenance guide [Thanks JD51MT]
4.Before I perform (2) above, provided I get her started, should I run her a bit to get all the fluids moving around, or drain and refill everything before I start her? Since she's been idle for 3-4 yrs, would it be safe to assume some condensation is in there that has not been burned off?
If there are any other things you guys recommend, pls let me know? I sure do appreciate your help and advice. Great to be back on the boards.
Hope everyone has a great Christmas and a safe, healthy New Yea
Regards,
tstex
Regards,
tstex
