I was doing it until John(UK) advised that the 15/40 oil keps dirt in suspension rather that letting it all
settle to the bottom. Now if you don't mind running the risk of dirt particles running through the Hyd pump,
cylinders, etc, then it should not be a problem.
6 Gal is the factory fill and a lot of people fill to the bottom bolt on the side PTO cover which is about 5
gallons.
Generally that is done with bad axle/brake seals.
gallons.
