oleredtractors
My light is not working. Can someone tell me how the circuit works and or provide a wiring diagram? Family had a 1066 growing up and this is a different 1066 with a cab I purchased. Overall seems good except wiring is pretty cracked up and can't keep lights working. When you turn on the key the gauges do come on but I have never seen the red light on. Initially it would kind of stick in gear and i had to turn off the engine to get it out of gear. I have adjusted the engine clutch, transmission brake and dump valve per the manual. I do have a service manual. It says "To adjust the dump valve, depress clutch pedal until stop lug "C" on clutch pedal strikes platform. Turn the dump valve operating screw "G" until lever "B" moves dump valve pin "AA" 3/8 inch. (IS THIS 3/8 INCH OF TRAVEL WHEN USING CLUTCH OR 3.8 INCH OF MOVEMENT PROVIDED BY ADJUSTING DUMP VALVE FORK?) Secure with jam nut. Seems to work ok but I would like to see that light working to confirm my adjustments are correct.
This post was edited by oleredtractors on 04/16/2022 at 02:09 pm.
