Removing weights to split tractor
I need to split my 1370 to rebuild torque limiter clutch.
I was going to build a gantry crane using a 3-1/2” x 7” I beam 10ft long to build a gantry crane. I figure my crane will hold about 1 ton safely Problem is I don’t think that’s enough crane capacity.
So…
I have 1400lb of front end weights on the front of this tractor I was originally going to remove all of the weights but what about leaving a few of the weights on the front to counter balance the front of the tractor.
Is this risky thinking?
Personally I would rather have a super heavy gantry crane but I don’t know if I can find a bigger piece of I beam.
The gantry crane I’m going to build is 10 ft tall 50ft wide at base and 10ft wide.
The I beam I have is 3-1/2” x 7” x10ft long the up-rights will be 3-3/4 drill stem which is about ½” thick
Any ideas or suggestions.
I’ve split this thing at the rear end twice now and have built a dolly to do so but have yet to split the tractor at the engine and I need a little more info like the size of crane I need to support the engine/front half of the tractor
So…
