mtf
- Location
- Bottom of the Bluegrass State
In response to your reply from a couple posts down about in rolling hay. I have really good success with in rolling hay and have for several years now. The ground here in south central ky is rolling, probably more than where you are. When the ground is very soft, I unroll in a different field to keep the cows from trampling and creating a muddy mess. When the ground is dry I will concentrate my feeding in one paticular field between 5 and 10 acres.
My rolls are 5 x 6 and I find that 1 roll to 40 momma cows works good for me. You need to feed only enough that they will eat in one day or they will start bedding down in it and messing in it.
I like feeding this way because you don't have the mess around the hay rings. It has reduced the number of cases of scours in calves. The cows distribute their own manure. Best of all I reduced the amount of hay I feed by 20%. It is not just me either most of my neighbors feed hay this way. Nathan
