Sediment bowl
Why are you getting that much water in it ? Might be a good time to review your fuel storage and handling methods ?
Plowhand, SLAP, SLAP, SLAP!! YOU asked the question, YOU have to accept whatever answers you get and be civil. If you don't like an answer just act like an adult and ignore it. If you can't just go away.
Showcrop ..... he's having a bad day, we've got to cut him some slack (LOL). Ha, I'm glad I'm not working next to him today on the assembly line. If a guy is using Classic View (instead of modern), he could at least figure out who is responding to who. Otherwise it'd be a confusing mess of a conversation.
Like I said I got the all the answers I needed from some respectfull sources on here the rest is all background noise..thanks
You'd be surprised at the amount of water and sediment/debris you can find in fuel now days.
I buy all mine straight from the pump, and have even found a wasp in the sediment bowl on my service truck.
Not to mention the 'water in fuel' light, that I didn't even know worked until a few years ago, now lights on a regular basis.
With the bio diesel mixes now being marketed, getting the water, and sediment out of it has become a full time job....Where the straight fuel of the past may have had occasional problems, but never to the degree the new junk does, at least not in my experience.
Wayne you're right on the money,I have sediment bowls with a screen and a clear inline filter on my gassers,pretty surprising how much crap the in line filter catches and I'm running
gas from the fuel station pump no on farm storage.Plus I have drains in the bottom of carbs and they collect water.
I haven't seen a problem with it in my fuel filter sediment bowl..but injector pump guy said water took out my pump so I'll take every precaution..thanks
What did you find.I have never seen a drain on the small units. Racor makes some good filters. Depending on what size you need
True story. Three nights in a row dad found the gas tank empty on the 730 Case we had parked in the field while doing spring tillage. Put more gas in and ran all day- never a leaked drop anywhere. Water had filled the sediment bowl to the point that when it got below freezing, the ice would force the bowl down and unseat the gasket. By the time we finished up with chores and hay hauling, the ice would melt and everything would seal back up.
Beagle
Regarding your response to Mike M, you have to face the fact that when you ask for help with a problem, some folks will try to figure out what's causing the problem, not just send you a Band-Aid to fix it. Doesn't seem like a bad thing to me, but I recall you have had some testiness issues on here in the past, so I guess I'm not surprised.
Awaiting testy response.
(quoted from post at 10:05:21 12/30/19) Coming out of tank its 1/4 but 1/2" diameter on the threads
I believe I get alot of water from condensation. I believe most of that is attributed to my tractors being outside and the climate I live in. I also believe that may contribute to ethanol gas going bad faster as it seems alot of guys on here dont have a problem with it. You could try a water separator funnel if you think it's in the fuel. A drain would be nice on a sediment bowl. Every time I remove one it seems to leak. I used a large O ring on the last one as that's all I had at the time.
these tractors come with a factory glass drainable water trap. you will never get that much water in the diesel unless it has been poured into the tank. plus its very easy to see the water in trap, and it works.
One could be made from pipe fittings just as you described for a air system -- just that you cant
see whats in there . As a bonus it will never get broken as easy as a glass water separator.
