Hey guys... well... when I first got my dakota, it had a hard petal... after a few days, they started squeeling, and so I replaced the pads, and the calipers, both with cracked pistons.
This was sevral hundred miles ago.
This morning, I loaded down my truck with steel, and headed off to the junkyard, about 30 miles away. As soon as I left, I noticed a faint smell of smoke. I figured that someone was burning something, and never really worried about it. A few more miles later, and I the smell was stronger, and I looked back, and saw that the whole side of the road behind me was covered in a thin layer of white smoke, and the other side was clear. Once I was two or three miles from the yard, I came up on a stop sign and saw white smoke pouring from the right front wheel. I pulled over, and took a look. All I saw was white smoke.
I pulled into the scrap yard and unloaded as fast as I could. The brakes were still smoking as I left, after unloading 1040pounds of steel, well under the 1450 pound limit on the truck.
Once I was out in the country, I opened it up and floored it, thinking I should get all the air I could going around that wheel. I took the long way home, to avoid town, and made it home the best I could, using the brakes as little as possible. I fishtailed into the driveway, and got behind the house as fast as I could, and grabbed the hose, and started spraying down the wheel. The water turned to steam as soon as it hit the wheel.
There was more smoke coming out from under the hood, so I opened that up. The smoke was coming from the bottom of the compppartment, about where the brakes were...
Here's some details:
When I took the old caliper off that side, the bolts that hold it on were really loose. So, when I put them back on, I used locktite, since I couldn't get the things to tighten up without it.
I diddnt usw grease, I used that blue brake squeel preventing stuff...
I reused the old rotor, it wasn't marked, scratched, etc...
The old owner told me the valve covers leak. That explains some of the smoke from under the hood possibly, but not the hot wheel.
Any advice here anyone?? What might have caused this, and how do I. Fix it??
