Kevin Godshall
Been working on my Dad's 2N front mount (won't start issue). Found low compression in #3 hole. Pulled the head and found everything to be in "visibly OK" order.
Got some recommendations to inspect the intake valve in question and also the guide.
Pulled the suspect and found out that he has a mushroom type valve with split guide. Once the top and bottom retaining clips were pulled, the valve and the guide pulled very easily out of the top. I called the neighborhood mechanic and he said I should not have been able to pull it out without using a valve puller.
Looking at the guide (I will try to post the pic), there was no seal whatsoever with it when it came out. I have searched online, but not found a seal that would fit it. On each side of the guide, there is a divider in the seal channel.
Does such an animal still exist as a seal for this type of guide? I see that the split guide is no longer available anymore. Should I just buy the solid body guide and replace the valve with the straight stemmed variety?
