jubileeguy
I recently convereted from a 6vlot to a 12 volt system on my NAA.
I had trouble with the starter and had to remove it.It was locked in the engaged position. I brought it into a repair shop and he opened it up for me to inspect it and it was pretty bad.A few wires on the armeture had dislodged and apparrently scored up the windings and he could see that it was apparently stuck on while the engine was running. At any rate I am seeking advice on replacement. Now that the tractor electrical system is 12 volts do I replace it with a 12 volt starter and will that fit?I see them for sale here on YT in both 6 and 12 volt. Also given these circumstances should I replace my current 6 volt selenoid switch with a 12 volt selenoid switch? Are there other recources for replacement starters that are recommended over YT.The shop I brought the starter too said he could repair it with some parts he may have around(no garauntee on performance etc) but that sounded kind of foolish given the circumstances. Thank You in advance for your assistance
