Two questions please:
1. Trying to replace a bent left-hand hydraulic lift rod and fork assembly on 2N. The pin that holds it to the hydraulic lift arm is stuck. I have soaked it with PB Blaster. Banging it with a rubber mallet but there is no room between pin and fender to give it a hard shot. 2 hours later if I have moved it an eighth of an inch I would be surprised. Any suggestions?
2. When I was installing a new right-hand leveling box assembly, I raised the hydraulic lift arms all the way up when I was lining up the holes at bottom of leveling rod fork with the lower lift arm holes. Now the hydraulic lift arms won t go down at all no matter what position I put the hydraulic lift control lever in. Once again, any suggestions?
Thanks very much in advance for any help
