Gentlemen;
I am in the final stretch of completing the restoration of my late Grandfather's 1950 G SER# 44495. I have worked this creature over from top to bottom. I assembled the clutch, and have tried every un natural act known to man and beast and it will not "snap" when trying to adjust it. The endplay on the flywheel is set to .010". The drive disk is new and has .125" hanging past the end of the crank splines, with a total runout on the face of .003". The Pulley assembly has a new bearing and bushing in it. the crank has a new race. The T-bolts were in good shape. The sliding sleeve has less than .125" rotational play(possible culprit). I looked at the dogs, and they appeared fine. I installed a complete clutch facing kit from WTR parts, which included the dual sided plate, the inner and outer floating plates and new springs and nuts. The clutch will not "snap" over when adjusted, and even with the brake backed all the way off, when adjusted too far, you can't turn the pulley with the lever disengaged. I have a call in to Mike Williams in Iowa and am awaiting a return call. I am really frustrated and I desperately need some advice.
Regards
Eric
Cell is 330-401-9224
Regards
Eric
