TD9 series B quit
69stang
TD9 crawler engine quit while driving. It does turn over fine. I have fuel to the Roosa injector pump. My thought is that the pump quit turning. Is this a common thing? I assume it is gear driven. Maybe one of you have a different idea what the problem is. Any help would be appreciated.
thanks
Tom
You can take off the timing window on the side and see if the pump is turning when cranking. If it’s not, the pump head probably seized and this will twist off the pump drive shaft.
