Well, a month or so ago I posted about reviving my '48 TE20 I've owned for 21 years. I put it away in'13 while working on
other Ferguson projects. My local rebuilder saved the Lucas starter and generator. I've since replaced the water pump,
installed sure seals on both rear axles, and normal tune up stuff to get it running. I actually got it running pretty decent.
Decided to adjust valves and found remnants of a milk shake on valve cover and top of head. Was hoping it was condensate from
sitting so long. No joy in mudville here. Adj. valves, buttoned up and ran it for about 20 min. No smoke, no steam out of
tail pipe, no miss, dry plugs, no antifreeze being forced out of radiator. After shutting off noticed a wiff of smoke coming
out of vent on valve cover. Drained about 7 quarts of green crap that is supposed to be oil. So, long story short, I'm the
proud owner of a very nice parts tractor. I think I'm down to the point of trying some block sealer unless you all have other
suggestions. Don't hold much hope for the block sealer.
Sorry for the long post but had to vent.
