Anonymous-0
So I finally decided to see if I can free up the telescoping steering on my 1655. I've owned the tractor for about 5 years and it's been stuck since I bought it. I took the upper unit out of the main body (charlynn style) and have been soaking the entire assembly in PB Blaster penetrating oil for several days. Still cannot get the button to push. I can see that the steel position lock ball is between 2 holes (which, I guess, means the button is already pushed). I've tried to loosen things with a hammer (gently) but it just doesn't want to move. My next step is to remove the 2 pressed-in pins to get the gear off the end so I can get a punch, or something similar, inside to try to hit the inner assembly (again gently). Am I missing something? Any other ideas on how to free it up? I plan to change the upper seal while I have it apart and replace the rubber cap on the steering wheel to keep this from happening again (I hope).
Scott
Scott
