The guy says it's a 57 but according to info I've found the 300 was built in 55-56. It's a rough looking old thing but starts right up, shows good oil pressure, goes through all the gears fine and doesn't seem to have any major issues. The PTO seal has a bad leak but other than that it's small stuff. Now I have a question about the hitch and the Torque Amplifier. I can see how the hitch is different from a 3 point hitch but I wonder if anybody that uses this hitch finds it to be a problem. I will probably use it for a snowplow/grader blade and a ground plow in the spring. I noticed it doesn't have draft control, I wonder if that might be an easy upgrade?
As for the Torque Amplifier, I think it works but I am not sure how it works. When I pull the lever back it comes to a point where it pushes the clutch pedal down. The tractor seems to slow down but is that only because the clutch pedal is being depressed or is that a part of the operation of the TA? The owner didn't know how it worked. I will get a manual if I buy this one but I am going to sleep on it tonight. For $1500 I think it's a decent piece to work on and use. Sorry for all the questions, but I am really excited about getting on a tractor again, it's been about 2 years since I owned one. Thanks guys!
