The Blackberry Control Thread
View attachment 168327Made the decision at around 5:00 AM not to spray until the large orifice discs arrived. At .75GPM it would take about 200 minutes to empty out the sprayer. THAT'S INSANE!!!!!!!!!!!!
Called the vendor at around 9:30 to get a tracking number. UPS has already handed it off to USPS...........AND IT'S OUT FOR DELIVERYView attachment 168328 Should be here at around 2ish.
View attachment 168329 That's cutting it close. Never had much luck at gambling, but I gotta say this one paid off. The gamble is/was that we won't get a freeze for about maybe 2 weeks. Got a solid week of rain in the forecast, and have to allow for the ground to dry out enough to support the tractor without causing ruts. That's about a week this time of year.
I figured the parts wouldn't get here for another couplayo days. Sometimes the bear bites you, sometimes you bite the bear.
EDIT:
If the discs arrive at 2, I should be able to empty out by 5ish(conservatively, considering travel time). Rain isn't supposed to start until tomorrow morning. Metsulfuron needs a 4 hour rain safe window. It's cutting it close.
If the rain holds off till 6:00AM Friday, we're golden. That makes for about a 12 hour window.
Could hedge your bet, only mix half a tank. I'm not much of a gambler either.
Looks like your weather down there is pretty much like up here in Oklahoma right now. We're green, and active, still. The latest rain, while thin in this particular area, got everything moving again.
This was early evening today.
We haven't even come close to dormancy yet. Temps still in the low 80's........ Our first frost is generally sometime in November.
The Blackberries under the high line have been there in some form for many years. The power company comes in on their right of way, and mulches them every couple of years. They come back faithfully. But, they've never really been a problem field wide. Same with some thickets further to the West.
Same plant, second pic is a closeup. If I'm identifying this correctly, these are new canes coming up after the cutting in July. They're almost everywhere in the field if you look for them. You can dam sure find them if you stick your hand in a windrow. You can also see the previous cane that was cut with the hay. Doesn't take long for a new one to pop up by the looks of it.
I think you're right about Fall activity, and spray timing. It perfectly agrees with what I've been reading. It sucks to try to become a Blackberry "expert" in a short time, but I'm doing the best I can.
While grabbing the bales, I took a little gallon sprayer up there, and put the entire gallon(Remedy) on the thicket under the high line. Let the wind carry it over the entire thicket. All leaves were wet, but not dripping. The tech people at Corteva called out 2.5oz Remedy/1oz surfactant per gallon for spot spraying(2% mixture). They seem to have a good customer service line.
AND.......I'm thinking I might put the clutch job off for a bit, slap some wheels on the sprayer, and try to lay on some chemical the whole field as soon as possible.
Was hoping to be able to work on the sprayer at my leisure, but it's not looking like it's gonna work out that way. I'm sure every hose, and all of the nozzles, have to be replaced. Everything is probably so brittle it'll crack if you look cross-eyed at it.
Seems like about 100yrs since I last calibrated a sprayer. Ooooomph.
A blackberry starts out as a juvenile plant with 3 leaves. As the plant matures it grows 5 leaves.
This plant allowed to overwinter will grow 3 leaves and fruit. After it fruits it will die. So technically the plant is a 2 year plant.
But the underground part can live for 20 years and it is always sending up new growth. So if you cut a blackberry to the ground all you did was reset the fruiting cycle. You did nothing to harm the plant.
Two ways to kill a blackberry.
Cut it down and cut any new growth right away. Without leaves the plant will slowly die.
Second and easiest is chemically.
To kill it chemically you need to apply the chemical after fruiting and before a frost IE in the fall. This is when the plant is taking energy out the leaves into the roots to survive winter. Don’t cut the plant prior to spraying. The more leaves the plant has the more chemicals it can absorb and send into the roots.
And don’t get in a rush. It can take 3 years to totally kill an established blackberry root system because they propagate by runners. Even if you kill the original plant the runners will sprout new growth next year.
I agree with what you're saying about application timing.
It's said, that Metsulfuron will give control in one application. Not total control...............studies have shown around 85% control. So, yes, it will have to be sprayed again.
I honestly won't know until Spring 2027. Wish me luck.
THAT'S INCREDIBLE, GREAT MINDS THINK ALIKE
.....................................I ONLY MIXED HALF A TANK DUE TO THE LATE HOUR, AND THE 2GPM TESTED FLOW ON THE GUN. I figured I had enough time before sundown to put out 100 gallons at that flow rate. Left the front gate at 4:30, got back at 7:03...............emptied out.
I am absolutely pleased with the new, larger, orifice. It came within a few feet of the advertised flow at pressure/gpm.
I can go to the larger D10 orifice, and apply more material faster. The distance, with my puny little pump, is the same as the D8 orifice..........but it puts out more chemical..........cutting field time........and engine run time. Probably use the D10 next time.
To get max distance, you have to hold the gun absolutely level. Point it up a bit, and you lose distance. It's a physics thing.
YOU DO NOT NEED A BIG PUMP TO DO GOOD WORK.
The Metsulfuron.......................
This stuff is a joy to work with.
1.5oz per 100 tank mix
Doesn't take up much space
Scale was tared with empty cup, then desired chemical added.
This stuff is amazing. Simple few stirs with a paint stick, and it's completely in solution.
The slurry was added to the tank when the tank reached 60 gallons. The 2 quarts of surfactant were added at this time. Finished the fill to 100 gallons with the agitator running full out. The agitator was run while in the yard, then the pto pump was switched off for the trip down to the field (around 3mi.). Agitator was turned on when I arrived at field, and run for the rest of the work day.
THIS STUFF PRODUCES NO FOAM
Chemical, and surfactant, mixed smoothly, and didn't foam up. You can't ask for better.
This was a "hot" mix by itself, and spot spraying is called out to runoff.......not just wetting the leaves. Leaves, and stems, are wetted completely. The mix itself is hot, and the application is large volume for the square footage.
Now I sit, and wait, for a few months(shrug). But it's the first step towards the renovation. If the freeze holds off, and conditions are dry enough to support the tractor............we'll continue spraying. The application today just scratched the surface.
BTW.....................for y'all safety police.
P-100 cartridges listed for pesticides.
I'm a cancer survivor(at least until the next CT scan). No point in pushing my luck.
You're an idiot to work with this stuff without at least minimal protection.
You have to know the biology to kill it.
When I got home tonight, it was dark, or nearly dark. The last of the spraying, before coming home, was done in near dusk conditions. Low light.
K'kins got home after I did. We sat down for supper, and talked like we usually do.
I was concerned that the plants might shut down at low light levels. They do rely on photosynthesis to live. I'm like this.............I question everything. She's used to it, and gives her opinion. We both felt that there might be some concern. I dearly love K'kins. She's an incredibly intelligent woman that you can talk to.
STOMATA. The pores on the leaves. How do they respond to light????????? Will it inhibit herbicide translocation??
So..................it could very likely be that the application, as the light was fading, was a faulty application. I might not get the benefit I'm anticipating.
The science is out there. You need to use it, to give yourself the greatest chance for success.
Bit of a Snafooooooooooooooo the other day.
The sprayer pump walked out of the PTO adapter sleeve, and tore it up. The shaft on the pump is harder than the adapter, so it survived relatively intact.
The old coupler had very stiff, almost non operational, set screws. I'm thinking they came loose, and the key came loose, and it was game on.
Some of it might be my fault. I'm thinking I might have left some slack in the chain that holds the pump on, and keeps it from rotating.
At this point, I've sprayed over 400gal of chemical on just the top of the meadow, still have the mid point, and bottom, to go. Not gonna get it done this year though. Temps due to drop down into the mid 20's next week.
Anyhoooo...............................
I suppose this is a lead-up to a mini fabricating project (always seems to be a fab project goin' on).
My fault/not my fault..........I don't intend to let this happen again. I'll be making a cradle for the pump that firmly attaches to the tractor drawbar slide thingy, that will keep it from moving rearward, and keep it from spinning.
One of the members suggested, or related, that he's using 1000rpm PTO to do stuff that otherwise would keep a stationary tractor revving to above 2000rpm to run a 540 PTO. I'll look back,, and find his name to give credit where credit is due. Zee plan is to get out the 1000rpm shaft (My Oliver has a 2 speed PTO) and build the cradle to fit it. Kill 2 birds with one stone. Ability to run the tractor at slightly above idle (around 1000ish rpm), and a new attachment to safeguard against my (maybe) stupidity.
EDIT:
I found the name. Bob Bancroft. Great idea......THANK YOU
