So I found out that the needle in the carb WAS indeed sticking, that is a whole nother story. Pulled the distributor, points looked pretty burnt and were gapped incorrectly @ .025, dressed them and regapped at .015. Checked timing while I was at it, looked pretty much spot on. Reassembled, hooked up my new adjustable spark tester, hit the button and saw spark and at that same moment the tractor seemed like it wanted to start! Then back to no spark. Jumped the key switch and that is where I noticed something I saw the last time I did it. I hooked an alligator clip to one side of the switch and it sparked? Nothing touching anything else. Any idea what is going on there? As mentioned before it was converted to 12V and rewired. I was sitting on the seat pondering things and all of a sudden I saw smoke coming from what I am going to call a junction block, looks like mica or something with 3 terminals, two on top have some sort of steel thingies hooking them together with either a threaded rod or a spring? I immediately pulled the hot terminal off the battery. I checked all the wires, and there aren't many, for any chafing or grounds but all looked ok. I did notice as I was cleaning up that I had left the key on, don't know if that could have caused it. Just for shits and giggles I hooked the battery up and tried to start it again briefly, still nothing. Touched that part that had been smoking earlier and it burned my finger. Something just doesn't seem right with all this. I'll try to post a pic of how it's wired up in case someone sees something glaringly wrong. I'm ready to pull my damned hair out if I actually had any!
