Mad Farmer
- Location
- Northeast
Just getting back to working on the TO-20 I got last fall. 1952 with TO-30 engine, still has TO-20 TSX361 carb.
I'd tore down and got the carb pretty well cleaned up last fall then progress stopped. I have the complete carb kit from here.
Besides a ton of rust in the bottom of the bowl carb was in pretty good shape. Had to use acid to get the rust out of the bowl.
Questions.
1) I got every thing out but the power jet. Passages/jet seem clean but I'm afraid I'll muck up the jet trying to force it out. I have a screwdriver that fits the jet in the kit well. No luck getting it to turn out. Should I chance it's clean enough? Air/cleaner passes through easy, I can see the orifice is clean with the little plug out. Thoughts on this?
2) I lost the little plug that seals the bowl underneath the power jet, there is not one in the kit. Is that same threads as the power jet?
3) I have an extra brass plug in the bag of parts. Can't find a place it goes and not on the IPL. It's brass and same thread as the main nozzle (1/4 fine?). Can get a picture if that would help.
4) Spring on choke shaft was rusted/broken. I assume the spring goes on to the hold the shaft in the open position, not choked. Correct?
5) I plan on reusing as many of the original parts that appear in good shape, save the rest if I need them later. Shafts seem to have no play can I skip replacing the seals packings?
Any advice appreciated. I did one of these MS carbs on my 9N ~ 30 years ago and that has not been a problem since.
Questions.
