Can anybody clarify this issue for me. The 450-B track adjuster piston rod seal that I purchased from a company named Factory Direct Parts is a nylon material as opposed to the black rubber seals that I removed. It was my understanding that the black rubber type was the only type that would work with this model. I called the company and the guy says this is the only thing available for the 450-b and it is what everybody is using. Comparing the old and new they are dimensionally the same but I dread the thought of having to break the tracks apart again if they won't hold the grease. I know it would be better to swap out the piston rods to a later model but the budget is tight. I installed one and fitted the yoke on it (it went on mighty easy) and pumped in some grease and have seen only a speck of leaking. It is moving the yoke out but is it going to hold when the pounding begins?
