Massey_165
I have about 4 acres I want to bale hay with, also want a tractor with a loader. I’m looking at old tractors like a MF 65, what size tractor or tractor recommendations do y’all have?
I bale with 65 hp caseihI have about 4 acres I want to bale hay with, also want a tractor with a loader. I’m looking at old tractors like a MF 65, what size tractor or tractor recommendations do y’all have?
There is more to getting a proper answer than just what size tractor.I have about 4 acres I want to bale hay with, also want a tractor with a loader. I’m looking at old tractors like a MF 65, what size tractor or tractor recommendations do y’all have?
Thanks for the info, I definitely look for live pto!I baled for years with a ford 3000, with a live pto... at 38 pto hp. It was worked but was fully loaded. The live pto allowed me to change gears without having to shut down the baler during the shift, so it worked well when coming to the heavy corners where the winrows were highest and a lower gear was needed. Then allowing a up shift on the straight aways again. BUT.. at 47 engine HP, a bit more hp and tractor size would have be better. I have bailed in a non live pto tractor and it was very bad as a gear change meant that the baler had to come to a stop in order to change gears and you had to then bring it back up to speed again, so it was a very slow tedious process to bale. And there are probably smaller square balers than the ford 545 deluxe baler (1965 model) I used.
We ran a small square baler for years with a Massey 65. They have live pto.I have about 4 acres I want to bale hay with, also want a tractor with a loader. I’m looking at old tractors like a MF 65, what size tractor or tractor recommendations do y’all have?
Noting your user name that’s the tractor I would recommendI have about 4 acres I want to bale hay with, also want a tractor with a loader. I’m looking at old tractors like a MF 65, what size tractor or tractor recommendations do y’all have?
I make hay on 3.5 acres and used a ford 8n. Which I had to use an Amish baler since the N didn't have a live pto. It worked great cause I could make hay in any gear with the tractor at an idle if I wanted! Another downside was the tractor isn't heavy and felt loose once the wagon got full. My recommendation is any tractor with a live pto that weighs 3000 pounds or more, somewhere 45hp and up. As far as what, the breed of tractor is whatever fancies you !I have about 4 acres I want to bale hay with, also want a tractor with a loader. I’m looking at old tractors like a MF 65, what size tractor or tractor recommendations do y’all have?
I remember an 8N pulling a baler that had a pull start Wisconsin motor.....................
