She has at least four areas in her house where there is a hole in the floor where water has gotten in thru the wall and caused the floor to rot. I removed a piece of sheet rock and you can see light at the top of the siding. The siding is not flat and stops about six inches from the top of the wall. Then there is horizontal trim piece that fits up under the drip edge and then down over the top of the siding. The trim piece is flat, and so there are gaps because the siding isn't flat. Is this a form of venting or a bad design? With the sheet rock off the wall, the siding is collecting a lot of condensation. If we put the insulation back in and close it up will the condensation problem go away?
TY
SDE
TY
SDE
