transfer pump
Geo-TH,In
I'm thinking of buying his. opinions? Fuel Transfer Pump, Fast 3.2 GPM Flow Gas Transfer Pump with Auto Stop Sensor Fuel Gas Can Pump, Rechargeable Lithium-Ion Battery Gas Pump, Red
The biggest thing to watch with transfer pumps is to make sure they are rated for gasoline.
Most are not.
I would want to see specific wording from the manufacturer that the pump is approved for gasoline not just an amazon seller saying transfer pump for gas can in the description.
ONE-CLICK START: Our gas pump no installation requires and starts with a single click! The built-in retractable strap makes it easy to secure the gas transfer pump hands-free. No longer have to worry about spilling which wasting fuel and having a strong smell of gasoline on my hands. It makes pumping fuel easy and quick without too much effort.
Do you have one? OR do you have a better one?
I think it would depend on your requirements. What is your need for the pump other than not getting gas on your hands?
I had a stroke. I need a way to transfer gas from a five gallon can to a tractor. lifting 5 gallons is not a good idea in my condition, What do you have? what do you recommend?
Dewalt I saw has a pump, does anyone have one? Was thinking of getting it. And I know George is a dewalt guy. Myself would be using for water and chemicals mostly.
I have a fairly expensive one that runs on AA batteries, I love it especially for the small engines like generators.
Mine will also work for diesel but you have to flush it after or the auto stop won't work for a bit.
I'm not in your shoes, but normally we use a manual hand pump if needed, but we also have an old 12v pump similar to this:
Well tractor supply links won't work but here is the image (you can probably find a generic on Amazon, maybe with the hoses too):
I can't find a 20v dewalt gas transfer pump, only water,. PLease post a link
https://www.terapump.net/collections/gasoline
I don't have one of these because I'm too cheap, but I have quite a few friends that have them and use them a lot for their race car fuel jugs. They work well for gasoline and they make another version for alcohol. I know Harbor freight sells one and so does Walmart, no experience with those though, and I'll probably buy one of them as my shoulders hurt to lift the fuel jugs.
I've got a hand plunger type pump. You can set the can with gas in it above the gas tank you need to fill, use the hand pump to start the flow and siphon the fuel into the tank.
Dusty
Looks like a cheap knockoff of a cheap Tera pump. Which leaks like a sieve because they don't come with gaskets, doesn't fit a lot of American gas cans and uses AA batteries instead of having a rechargeable.
You do realize all you are getting is a pump with a suction pipe that you stick in a gas can and dispenser hose with a valve right? Hope it comes with a way to secure it to the gas can. If not the suction hose will pull out of the can if you lift the nozzle to high.
If so. It should work for you. No higher than the fuel tanks are on a Terramite, small Kubota and riding mowers. Good luck with it.
I'll stick with my 20+ year old Fill-Rites.
