Cowboy1961!
JD 2030 moving logs and lift stopped working. The two way valve had excessive play in lift handle so put new two way valve on. Didn't fix it. Then bought new hydraulic pump on front of tractor. Didn't fix it. Changed oil and all filters no difference. Pulled and inspected pressure relief valve and bypass valve, all seemed fine. PTO works, power steering works, rockerarms work but does vibrate on lifting, which has done since I bought this tractor a year ago. I have not checked pressure though, mainly because I don't have a way to check it. Unless someone knows or can tell me a easy way to check it. Anyhow I sure would appreciate any kind of helpful advice Please..thanks in advance
