Tw15 valve stack
Tw15 series 1 has blown the orimgs between the hydraulic remote valve stacks twice this year. What would cause the issue. Figured maybe old orings sitting on the shelf from cnh too long? But twice
Improper assembLy? Warped or damaged valve body or cover?
A little more history might help - e.g. did this start on its own or after work was performed? How many orings and where?
TOH
About the only thing I can think of other than defective or wrong orings would be either improper torque sequence of the cover, or else the pressures are in excess of rated specs. For the latter to happen there would have to be a stuck closed relief valve, which is pretty much unheard of. Easy to check for though, just stick a pressure gauge in any remote coupler and pull the handle back. Going from memory, you shouldn't see much more than 2500 PSI.
I replaced them about 2 years ago when i put a new hydraulic pump and rebuilt the pto. They lasted till this spring where the blew out spraying oil everywhere. And they just did it again. I would like to put a gauge on but i cant use either remote as it sprays oil everywhere from both levers. I used grease to hold the orings in place to reassemble.
Some pictures with arrows drawn in by yourself would be nice about right now.
Its leaking in between the 2 remote valve bodys under the cab. Theres 3 orings per stack and the cover. So when i pull the levers its sprays oil out from where it blew the orings. I suppose ill have to throw another set of o rings at it and take a pressure test. The first set lasted about 2 years the second set lasted about 6 months
Thats for the coupler itself i think your thinking of. My issue is between the valve bodys under the cab where the bolt the stack together. Its leaking between the 2
With a leak like that a pressure test is basically meaningless. I also can't imagine this sort of static seal failure from over pressure. Those seals are pretty stout and I expect something else would probably fail first.
Check the face of the sections for flattess - no more than a couple thousandths out.
Check the glands for damage.
Check the tie rods and threads to make sure they are not pulling out under pressure.
Check the protrusion of the new orings when installed in the glands. Depending on the cross section of the o-rings it should be .010 or more.
Cast iron sections are also easily cracked if they are clamped down unvenly - e.g with contamination on the face or when warped.
TOH
