(quoted from post at 12:14:03 10/08/23)
If it is the old prestone style and a leak develops, the stuff is deadly to all critters.
And they like it because it is sweet.
rue, but it takes more than a few drops. Find a SDS for the toxic dose, it is a fair amount.(quoted from post at 12:14:03 10/08/23)
rue enough & I too, use it for ballast.(quoted from post at 10:10:02 10/09/23) Yes you can use it for ballast. It is no more toxic... than the diesel, gas, hydraulic oil, 90 wt, atf, battery acids, or grease.... that leaks out of your tractor, car or truck buses and dumptrucks. So remember not to play with plutonium. BACK ON TOPIC, it makes a very very quick and easy ballast for tires, that does not freeze and contains rust inhibitors, water pump lubricant, and acid fighters,,,, that water does not. And no worse than the caustic chloride solutions used by others.
17 states prior to 2013 required bittering agents to be in it.(reply to post at 17:35:43 10/08/23)
f I had never tasted it, I would make a snarky remark about that. The idea that if you haven't seen it, it doesn't happen, just doesn't hold water. Not everything always happens every time. Sooner or later, it will happen, so you still need to handle EG responsibly. Nothing over the top, just don't leave open containers unattended.(quoted from post at 18:39:06 10/09/23) i dont even like taste .
So if your weigh 75kg (165 lb) it should take about 4 oz of concentrated or 8 oz of 50% diluted EG to kill you. Small animals obviously weigh less so it takes less and sensitivity varies by species, so it could be a very small amount for a small animal. A thirsty small critter can conceivably drink enough if it is running down the side of a tire.A potentially lethal dose of ethylene glycol is approximately 1-2 mL/kg of 95% concentrated solution, or about 1,500 mg/kg. https://www.ncbi.nlm.nih.gov/books/NBK537009/
