Anonymous-0
Does any one have the wiring diagram for a 16 hp Vanguard twin? I think I know, but I'm not sure.. single red wire, coming from what appears to be a solid state voltage regulator on the the side of the engine should be tied into the positive side of my battery, to charge, right? (through the key switch). But, then there are two more wires, one that goes to an insulated stud on the side of the engine, between the fuel pump and the regulator (?) and a gray wire that goes up under the cowling... is the single wire going under the cowling the ignition wire, and should it be "hot" to run and the single wire on side, what is it for? Is IT the ignition wire, or is it a "kill wire" that grounds out the ignition system? any help would be appreciated...thanks
