WD oil leak help
My 53' WD has a oil leak in the rear and i need your help. It leaks from both sides in the same spot. It looks like there is a "hole" that goes into the diff. on both sides on the bottom. Anything I can do to fix this? This tractor is fairly new to me.
You guys have been a great help in the past. Thanks...........Brennon
Im going to try to post a pic
Lets try it again
It is coming from the brakes compartment, you have probably leaking diff seals or final drive seals
I would guess it is the differential seals
