wd45 hydraulics
Anybody know what this is for? It is the drain under the hydraulic pump. (1st pic) Can I just put a plug in there? It is cracked and leaking hydraulic fluid.
Second pic is a quick connect for a remote hydraulic setup at the rear, are these universal, it is leaking. I know ACs are a higher pressure system than most others. Where is the best place to get a replacement?
Also what should I use to seal the threads on these fittings?
Thanks for any help,
Mike
[/url]
Pics didn't attach the first time.
The drain pipe off to the side is not factory...probably PO had attached a reservoir to that pipe for extra capacity for a loader, etc. Remove the pipe and put in a plug. Can use gasket sealer for sealant. The remote coupler is a Pioneer style, common on AC and some other tractors.
(quoted from post at 19:08:43 09/23/18) The drain pipe off to the side is not factory...probably PO had attached a reservoir to that pipe for extra capacity for a loader, etc. Remove the pipe and put in a plug. Can use gasket sealer for sealant. The remote coupler is a Pioneer style, common on AC and some other tractors.
Thanks for the reply, any idea where I can get a replacement for that coupling?
