Jim.ME
- Location
- central ME
I would say a kicker and several wagons (and good tarps) might be best, especially when it is just you. Your other two hands can be unloading into storage while you fill wagons.I can't tell you how many bales per day on average, I usually cut based on how the weather is. Based on last year, the forecast was never accurate and I had fields rained on more than once, the quality really suffered. With that said, the struggle is usually beating the weather. So sometimes I won't cut too much if it looks iffy, sometimes i'll cut the whole field.
Amount of people varies, if it's a weekend it would only be me. I'd be dropping them and then coming back and picking them up by hand. Max amount is usually 3 people total.
A bale basket can work if you have 3. If you are alone at least when you dump the basket the pile is in one spot you don't have to walk the field. It's not fun but we have done 1000 (+/-) in a day, chuting some on to wagons and the rest into the basket dumped at the barn to the barn or at the back of a box trailer with three people (one baling with two handling).
An accumulator needs a power unit and driver to gain much. If you are alone, you bale then you have to gather and load. And you need wagons enough to transport what you have baled, or you lose time unloading/storing.
As mentioned with the self-propelled bale wagons many need a storage location they can self-unload (tip up to dump the stack) into, not the type of storage you described.
Just my thoughts, others will have different thoughts, which is fine. You need to look at the process from baler to storage to see which will work best for your crewing and facilities.
