Grade 8 for a shear bolt ?????
You must be looking to do some gear box repairs.
Most manuals will tell you to use grade 2 for safety reasons.
But in secret the techs will tell you to upgrade to grade 5 because grade 2 bends rather than shears making it hard to get the broken piece out.
If you are looking to upgrade to a 8 you need to either clear the obstacle course so you quit running over junk or I more likely suspect you are using the wrong bolts.
Case in point....
The threaded section of a grade 8 bolt has less shear strength than the shank of a grade 5 bolt.
If you are using normal bolts the threaded area is usually in the shear point.
You need full shank bolts with just a small section of threads.
Yes it is a special bolt and hard to find other than getting OEM parts.
Another option is to buy fully threaded bolts.
In this instance you might get away with using grade 8.
A lot of OEM shear pins; wrongly called shear bolts are special made alloy to break at a specified shear point.
You can usually spot them as proper shear pins because of the groves cut in them.
