(quoted from post at 21:01:56 07/14/22) bmoran4 .Are you sure you have the clutch plate installed correctly?If it is put in backwards it will hang up and not release. The spring side of the clutch disk must go toward the pressure plate.Short side towards the flywheel.
(quoted from post at 06:45:47 07/15/22) Assuming it is the correct clutch disc and pressure plate something must be wrong with the clutch throw out arm, bearing or linkage.
(quoted from post at 10:23:19 07/15/22)
Once you confirm all the linkage is working as it should with no cracks are broken pins Its probably going to be best you remove the steering gear to see what's going on...
The linkage will humble you its best to have someone work it while you inspect every piece of it. A crack is hard to see unless its under compression.
Once the release bearing contacts the clutch fingers the the total travel is about 3/8" it only takes about .050 of clearance to completely release the clutch from the pressure plate. Its not a big of a throw as you would think it would be.
Tips in this post
https://forums.yesterdaystractors.c...ostorder=asc&highlight=clutch&start=0
(quoted from post at 18:45:40 07/15/22) bmoran4, back on June 20th you said, "New pressure plate and clutch disc installed. Now the clutch pedal has no "feel"/resistance to it. Clutch will not disengage....."
Did you get that resolved, what did you find?
With the last few minutes of sunlight tonight, I will see if I can get the steering wheel off. If it comes off, that will give me the motivation necessary to carry on and see what findings I can come up with.(quoted from post at 19:15:15 07/15/22) If you have confirmed the linkage is intact and functional the only window you will have to the inner workings is removing the box...
Are you can remove the flywheel assemble the clutch set to the flywheel put it in a press move the fingers 3/8" max to check for release of the clutch disc.
If I had the luxury of a window I am taking it : )
(quoted from post at 19:47:54 07/15/22)With the last few minutes of sunlight tonight, I will see if I can get the steering wheel off. If it comes off, that will give me the motivation necessary to carry on and see what findings I can come up with.(quoted from post at 19:15:15 07/15/22) If you have confirmed the linkage is intact and functional the only window you will have to the inner workings is removing the box...
I kind of agree on that. I just don't know why. I can't get the clutch pedal to adjust favorably, and in my other thread, I went around and around and around on clutch plate orientation. I am 1000000% sure it was right every single time. Longer nose away from the flywheel towards the pressure plate/transmission. Shorter nose towards the flywheel/engine. You can see the long nose here to verify orientation currently:(quoted from post at 19:48:00 07/16/22) By the looks of your two pictures the throwout bearing is not moving the clutch fingers. If this is the case that clutch is not the right one
or you may have the pressure plate in backwards.
(quoted from post at 21:33:03 07/16/22) bmoran4 ,From your picture that looks like the side that goes toward the flywheel by the nose on the clutch disk.You should be able to see the spring side and I don't see them.
(quoted from post at 12:41:13 07/17/22) It really does look like the disc is in backwards from your picture. The throwout bearing is moving and the fingers are moving.
Here's an ebay ad for a clutch disc with a good side view. The side that has the raised portion where the springs are is the side that faces the pressure plate.
https://www.ebay.com/itm/152871873736
(quoted from post at 11:21:01 07/17/22)(quoted from post at 12:41:13 07/17/22) It really does look like the disc is in backwards from your picture. The throwout bearing is moving and the fingers are moving.
[size=24:000255f611][color=red:000255f611]THE CLUTCH PLATE IS NOT BACKWARDS!!!!!![/color:000255f611][/size:000255f611]
The flatter side, smaller nose is to the flywheel. The larger nose, with the protrusion for the springs faces the transmission.
It doesn't show well on camera, but the depth of spring housing protrusion (red arrow) is basically equivalent to the thickness of the actual pressure plate of the pressure plate assembly (green arrow). If it were in backwards, the spring assembly on the clutch plate would be more forward of the actual pressure plate.
Apologies for being obstinate on this, but I insist that all three times, the clutch plate orientation has been proper, including the current time.
This post was edited by bmoran4 on 07/17/2022 at 11:26 am.
(quoted from post at 15:46:28 07/17/22)
Well, I will be obstinate as well. As I posted earlier you should always measure before putting it together as Hobo showed. And don't worry about being obstinate. There is at least one a week who comes here for help insisting that his problem can't be a common easy one. His has to be an obscure hard one.
(quoted from post at 19:11:28 07/17/22) bmoran4, I really feel your frustration on this. I got to wondering, is it at all possible that the machine shop gave you the wrong flywheel? Like you said, it all worked well before you took the flywheel in to have the ring gear replaced.
(quoted from post at 19:10:04 07/17/22) Could be clutch is OK, something else keeping it turning. Frozen pilot bearing?
Long time ago someone told me this story, or I read it somewhere, or maybe I dreamed it.
Story goes these old boys had put a clutch in something and it would not release. They had checked and double checked and triple checked, all was as it should be, just would not release. So they took it apart again and found- NO pilot bearing.
Kinda seems like someone told me that story once.
N pilot bearing is installed in flywheel, not in crankshaft.
(quoted from post at 21:42:55 07/17/22)
(quoted from post at 07:37:44 07/18/22)
If the fingers are moving 3/8" the other thing you can do is remove the left floorboard so the pedal will have more travel. Either way the clutch is coming out for inspection.
Remove the flywheel assemble the clutch and put it in a press. Manually press on the fingers and check for clutch release.
Proper clutch adjustment has noting to do with clutch pedal free play it all has to do with clearance at the release bearing to clutch fingers.
(quoted from post at 06:58:35 07/18/22) [size=24:e43185f389][color=red:e43185f389]THE CLUTCH PLATE IS NOT BACKWARDS!!!!!![/color:e43185f389][/size:e43185f389]
(quoted from post at 19:10:20 07/18/22)(quoted from post at 07:37:44 07/18/22)
The fingers DO NOT move anywhere near 3/8" when in contact with the bearing - maybe a 1/16 of an inch at most.
This is exactly what I tried to do with the clutch pedal adjustment to no avail. I've tried adjusting the clutch (after noting the position it was in) and wasn't able to do any better. The FO-4 isn't very helpful in technique - just 3/4" petal play is given, and I'm not sure how to achieve that. It wasn't that way when working anyways, so I just put it back where it was (counted turns). I would appreciate any methodology suggestions you (or others) may have.(quoted from post at 11:21:09 07/18/22) So are you saying that the throwout bearing moves a long way before it contacts the clutch fingers? I'd take all of the play out and see how much it moves the clutch fingers and if it releases the disc.
(quoted from post at 22:46:10 07/14/22)
The currently installed pressure plate levers do not have any adjuster screws
(quoted from post at 09:10:20 07/18/22)The fingers DO NOT move anywhere near 3/8" when in contact with the bearing - maybe a 1/16 of an inch at most.
(quoted from post at 19:02:37 07/18/22)
You are the one with the eyes you will have to find out where the issue lies. By now as I original thought your issue is in the linkage. When I said I had cracked parts you could not see a crack unless the linkage was under compression. No load the crack closed up.
You should be able to adjust the release bearing up to zero clearance then back off till the fingers do not constantly spin the release bearing
(quoted from post at 19:23:20 07/18/22)
If indeed, your pressure plate does not have release lever adjustment screws, throw it away and get one that does.
I've probably done a hundred or more clutch jobs on tractors, and learned a long time ago to check the height of release levers every time.
(quoted from post at 16:25:51 07/18/22)(quoted from post at 19:02:37 07/18/22)
Why wasn't this suspected crack not an issue before the ring gear was replaced? I have inspected the clutch release arm to the best of my abilities with no obvious crack found. However, I also have a serviceable (used, new to me) clutch release arm and shaft in the mail.
How do I do this? My last attempt did not have the right technique to accomplish anything.
(quoted from post at 07:06:38 07/19/22)
Bmoran, see my first post to your thread. Why come looking for help and just ignore or argue with all attempts to help you?????
It is a lot easier to check it before putting back together as Hobo told you.
(quoted from post at 09:05:35 07/19/22)
In one of my links I show and tell how to use a level and a tape... I also express if you don't have those tools you need to turn in your man card.
(quoted from post at 12:56:05 07/19/22)
Not trying to be a WA but you said yourself that it all worked before you took it apart and put it back together. You can't blame us for thinking it's human error.
(quoted from post at 18:39:19 07/15/22)(quoted from post at 19:47:54 07/15/22)With the last few minutes of sunlight tonight, I will see if I can get the steering wheel off. If it comes off, that will give me the motivation necessary to carry on and see what findings I can come up with.(quoted from post at 19:15:15 07/15/22) If you have confirmed the linkage is intact and functional the only window you will have to the inner workings is removing the box...
Okay, update: Steering wheel came off so easy that it would make anyone jealous. Not even 30 seconds. Just remove the acorn and the wheel was loose and came right off! So, with that dreaded operation out of the way, I attempted to remove the dash. It took me too long to figure out the throttle stick needed to come out. That took some WD-40 and angry words, but once it was out, the dash could be separated to allow access to the steering box mounting bolts. They came off nice and easy too. All in all, not too bad. I was really dreading the steering wheel. So, now I have a window and I'm still scratching my head...
Here is the clutch pedal in its "resting" position:
And here it is with the pedal all the way down and you can see witness marks showing it moved about 3/4 or a little more of an inch:
(quoted from post at 10:58:56 07/21/22)(quoted from post at 18:39:19 07/15/22)(quoted from post at 19:47:54 07/15/22)With the last few minutes of sunlight tonight, I will see if I can get the steering wheel off. If it comes off, that will give me the motivation necessary to carry on and see what findings I can come up with.(quoted from post at 19:15:15 07/15/22) If you have confirmed the linkage is intact and functional the only window you will have to the inner workings is removing the box...
I hope your pictures made it when I quoted this. In the one picture I can see the throwout bearing sliding on the sleeve about 3/4". If it's moving that far and not pushing the fingers something is wrong right there. You should be able to adjust to the point that the throwout bearing is almost touching the fingers with no pressure on the pedal. If you're looking right at the linkage while you operate the clutch pedal it should be obvious is something was cracked or a pin was sheared.
(quoted from post at 16:58:14 07/27/22)(quoted from post at 10:58:56 07/21/22)(quoted from post at 18:39:19 07/15/22)(quoted from post at 19:47:54 07/15/22)With the last few minutes of sunlight tonight, I will see if I can get the steering wheel off. If it comes off, that will give me the motivation necessary to carry on and see what findings I can come up with.(quoted from post at 19:15:15 07/15/22) If you have confirmed the linkage is intact and functional the only window you will have to the inner workings is removing the box...
[size=18:f485fdaf30][color=red:f485fdaf30]RESOLUTION[/color:f485fdaf30][/size:f485fdaf30]
The clutch plate was NOT in backwards ever. There were no cracks in the shaft/pins/arm. The clutch parts were the correct parts and not defective.
I had my helper over again fully anticipating splitting the tractor. I went over every gem of knowledge, manuals, diagrams etc with them and brainstormed. We decided to attempt to adjust the clutch release arm once again just for the heck of it. Somehow, this time, together, we achieved the adjustment we needed. I wish I knew what the magic was, because I spent a solid half day and a an hour or so on another day on my own trying to get it right to no avail, and I wouldn't classify myself as mechanically inept. [b:f485fdaf30]*shrug*[/b:f485fdaf30] More hands and eyes to keep everything together?
At least it is resolved, and it wasn't the clutch plate in backwards. A big thanks to all who provided guidance and persisted along with me.
(quoted from post at 17:29:21 07/28/22)(quoted from post at 16:58:14 07/27/22)(quoted from post at 10:58:56 07/21/22)(quoted from post at 18:39:19 07/15/22)(quoted from post at 19:47:54 07/15/22)With the last few minutes of sunlight tonight, I will see if I can get the steering wheel off. If it comes off, that will give me the motivation necessary to carry on and see what findings I can come up with.(quoted from post at 19:15:15 07/15/22) If you have confirmed the linkage is intact and functional the only window you will have to the inner workings is removing the box...
[size=18:352f74993f][color=red:352f74993f]RESOLUTION[/color:352f74993f][/size:352f74993f]
I had my helper over again fully anticipating splitting the tractor. I went over every gem of knowledge, manuals, diagrams etc with them and brainstormed. We decided to attempt to adjust the clutch release arm once again just for the heck of it. Somehow, this time, together, we achieved the adjustment we needed. I wish I knew what the magic was, because I spent a solid half day and a an hour or so on another day on my own trying to get it right to no avail, and I wouldn't classify myself as mechanically inept. [b:352f74993f]*shrug*[/b:352f74993f] More hands and eyes to keep everything together?
The fact remains: To prevent this problem, as Hobo advised, measure and verify distance from release bearing to fingers before assembly.
