catfisher5
Anyone changed out pro seal on Myanmar 2301d, does the whole pro housing need to come off to get to the seal?
I can see a snap ring in housing but not enough room around it to open to take it out. I'm thinking the pro shaft has a seal sleeve on it under the seal id.I have not done it but based on the parts manual drawing you should be able to remove the seal and install a new one without taking anything apart. Many hits on part number 19430-26350 (TC42609) 42mm x 60mm x 9mm. Drawing shows a snap ring in front of it that would have to be removed.
Fredricks Equipment - Agriculture dealer offering parts in Hartselle, AL, near Florence, Birmingham, Madison, Huntsville, Nashville, and Athens
Fredricks Equipment in Hartselle, AL, offering parts of agriculture equipment near Florence, Birmingham, Madison, Huntsville, Nashville, and Athensfredricksequipment.com
Your YM2310D is a Gray Market machine. There are only a select few places in the country who even know these machines inside-out. Fredricks Equipment in AL, the other place in northeast WA and a few places in CA.So the hole is maybe 1.5 to 1.625 in housing" and pto shaft is 1.375 od, it looks like to get to seal the whole housing has to come off, maybe with gears and all. Just don't seem right to have to just change seal out. There must be Some tractor shop that has worked on a 2301D.
Got new 15 amp alternator coming with two wire t- plug,does it matter which way the two harness wires go into t- plug that go up to the rectifier/regulator. Tractors a yanmar 2301D.
Even electrical gurus use schematics. Are the wiring schematics in the Yanmar manuals? Do they tell you the landing points of both ends of wires, not just colors? Alternator model/manufacturer? Is it a regulator or rectifier? That info helps in almost every case.I know there are some electrical guru's lurking somewhere.
