Keith (Southwest MI)
Last Oct my dad passed away and we have since suspended the dairy operation. 60 years of farming and acumulting equipment have come to an end and we are contemplating have an auction this spring. Most of the equipment (not on the list below) I have no problem getting rid of but the Ford stuff I"m struggling with. The Jubilee listed is the first tractor I ever drove, back when I and that tractor were both around 6 years. The 801D SOS with the front plow is what I used to open the 1/2 mile of road in the winters so dad could make it in from his second shift factory job in town. I"d like to keep it all but that isn"t practical or even feasible unless I leave it at the farm. I"m considering buying the 801 w/front plow, the 801 with the single arm hydraulic loader and the jubilee. Once it"s gone, it"s gone. What would you do.
Corn picker, Single row, mounted
Irrigation pump with 4-Cylinder Ford Diesel engine
Manuals, Misc Ford tractor and equipment
Boom (Crane), 3-pt
Drawbar, Fixed, V Style
Flat Belt pulley ____ Spline
Half Tracks
Loader, Single arm, hydraulic trip (mounted on one of the 801D tractors)
Loader, Single arm, Mechanical trip converted to hydraulic trip (mounted on one of the 801D tractors)
Rear Blade, modified, 6", 3-pt
Rear Manure fork (cylinders mounted on Jubilee)
Slip Scoop (non-reversible), 3-pt
Swinging Drawbar assembly for 8N,NAA,hundred series
Wheel weights, Front
4-Spooler hydraulic control for 800/801 series tractor
Air filter intake for 800/801 series tractor
SOS transmission, parts
SOS transmission, rebuilt but had a sticky valve, owner at the time had a 4-speed installed in its place)
Cultivator, 3-pt, with side shovel assembly, converted for Side Dressing
Cultivator, Field, 3-pt
Plow, 3-16, 3-pt
Ford 641 Gas, Sherman Over/Std/Hi range, rear wheel weights
Ford 801 series Diesel Select-O-Speed with remote hydraulics, Front Dozer/Snow Plow attachment, wedge/pie style rear wheel weights
Ford 801 series Diesel Select-O-Speed with remote hydraulics, Single Arm Ford Loader, Booster cylinders for 3-Pt lift, wedge/pie style rear wheel weights
Ford 801 series Diesel Select-O-Speed with remote hydraulics, Single Arm Ford Loader, wedge/pie style rear wheel weights
<a href="http://i58.photobucket.com/albums/g271/keithw_2006/DSC00922Ac.jpg" target="_blank">
</a>
Boom (Crane), 3-pt
Half Tracks
Plow, 3-16, 3-pt
