I posted a few days ago about this thinking maybe steering was bypassing but I've unhooked the pressure line going to the column and installed a pressure gauge. Thought I'd see if it worked with it unhooked and it still does the same thing. Meaning lift won't work unless you move a leaver that's goes to the break away couplings on the back. Once you move it the lift will work like it should but you have to move it every time for the lift to work or hold it all the way forward. Same as steering turn it one way or hold it and lift will work but right now steer is unhooked. Pressure reading ( stand by pressure) is around 2700 - 2900 at the line going to the steering column. Is this wright or a little high? Operates about 1400-1500 when you raise the lift. Any ideas on what might be the cause with the lift not working until you use something else hydraulic? Thanks for the help..!!
