John Achmann
Guy brought me an 1175 for some repairs. He said he
overhauled the engine around 200 hours ago. He did the
work himself. Not a mechanic but knows that stuff needs
to be clean and torqued. So ever sense the overhaul the
tractor had a ticking sound that sometimes is a knocking
sound. He asked if I could figure out that problem. So
tore into the engine. Heads had to come off anyway as
the gasket leaked antifreeze externally. I looked over
everything as it came apart. Pulled pan checked
everything over on lower end. Made the decision to pull
pistons as Im right there and wouldnt take long. Cleaned
everything and didnt really find anything that sticks out.
Heres my question, as Ive pulled pistons and kinda plan
to reuse the rings should I hone the cylinders a little and
reassemble? Dont hone and reassemble? What would
you guys do? Dont really want to replace the rings as
these look ok. Ive had different opinions over the last 25
years of being a mechanic on issues like this.
